Маленький вопрос по абревиатурам.....
Можете смеятся.. но так и не нашол толком как расшифровуеться абревиатура DC у Сигм.. Ну например стёклышко
Sigma 17-70mm F2.8-4.5 DC MACRO for Canon
17-70 - это с учётом кропфактора кенона или нет?
Надо множить на 1,6 или фокусные растояния уже "прощитаны" как у EF-S....
Если спросил прописную истину - прошу модераторов удалить тему - а ответ написать мне в ЛС =) Или на почту.
Спасибо
Re[JuJik]:
от:JuJik
Спасибо
Добрый день. Поиск конечно же рулит ну да ладно.
SIGMA (http://www.sigmaphoto.com/lenses/lenses_all.asp)
Большая часть сокращений описана по русски здесь: (http://sigmalens.ru/technology.php)
ASP
Aspherical lenses. Lens elements that are not spherical can reduce the total number of elements required in a lens design. They can deliver better performance while reducing weight and size.
APO
These lenses use apochromatic design and Special Low Dispersion glass (SLD) for minimum color aberration and ultimate telephoto image quality, improving contrast and sharpness.
HSM HyperSonic Motor. Enables virtually silent, highly responsive auto and manual focusing, as well as manual focus only override.
UC
Ultra Compact. The smallest, lightest lens of its type available.
DL
Deluxe. DL lenses are full feature lenses in spite of their modest price. Like other Sigma lenses, they are supplied with a custom lens hood and feature half-stop increments on manual aperture settings, depth of field scale, distance scale, infrared correction mark.
DF
Dual Focus. It is easy to hold the lens, since the focusing ring does not rotate during auto-focusing and yet provides adequate focusing torque of the focusing ring during manual focusing of the lens.
HF
Helical focus. This system of the lens eliminates front lens rotation, thus allowing the use of a Perfect Hood and easy to use polarizing filter
RF and IF
Internal and Rear Focusing. Conventional automatic focusing is done by moving either the entire lens system or just moving the front lens group. For our telephoto and telemacro lenses, Sigma developed an internal focusing system that moves lens groups inside the lens barrel, significantly improving macro capabilities. For super wide-angle lenses with large front diameters, we created a rear focusing system that moves only the rear lens group. For our mid-range lenses, we use an internal focusing system that moves inner lens groups to allow a shorter minimum focusing distance. All while retaining a constant physical lens barrel length.
DG
The DG designation applied to certain newer Sigma lenses (mostly wideangle and wide zoom type lenses) indicates that the lens is especially suited for use with digital SLR cameras. The DG lenses feature improved (more even) light distribution from image center to edge, especially at maximum aperture, compared to conventional fast wideangle lenses. This is important in digital photography, but is also useful in 35mm photography, especially when slide film is used. Also, the shorter focal lengths are desirable, because most digital SLR cameras have image sensors whose dimensions are considerably smaller than a 35mm negative (usually by a factor of 1.3X to 1.7X), making the lens’ angle of view equivalent to that of a longer lens on a 35mm cameras.
DC
Digital APS-C lenses.
EX
Excellence. These professional type lenses feature the distinctive EX finish and EX logo on the lens barrel.
OS
Optical Stabilizer.
___________________________________________________
Фокусные расстояния всегда пишуться в эквиваленте 35-мм системы, то есть если у вас кроп то эти значения умножаются на кром фактор.
а абривеатура EF-S говорит только о том что данная оптика будет работать только на 1.6 кроп тматрицах (просто физический размер линз меньше и он подогнан под меньшую матрицу - из за этого уменьшение цены и веса.)И байнет там другой - на ФФ уже не оденете такую оптику.
Удачи в фотографировании, но поиск и тематич литература творят чудеса
Re[skyfinn]:
1. DC (Digital Crop) - это именно для кропнутых камер.
DG (Digital Grade) - просто оптика, адаптированная для работы на цифре, не кропнутая.
2. 36мм систем не существует, есть 35мм.
3. При равном ФР и светосиле сколь-нибудь заметного уменьшения цены и веса кропнутой оптики не происходит (бывает даже наоборот). Обсуждалось многократно. Пользуйтесь поиском.
Re[JuJik]:
2*skyfinn*
Это я находил и не раз.. =)
2*zalex*
[quot]1. DC (Digital Crop) - это именно для кропнутых камер.[/quot]
Спасибо, это именно и интересовало...
