Приборчик выходит достаточно тяжелый, почти 3кг, но есть возможность приделать голову отдельно. На мой взгляд очень вкусно , надеюсь на адекватную цену.
MODEL AD600
Wireless slave mode *Local(none)*optic(compatible with Nikon & Canon)*2.4G(compatible with Nikon & Canon)
Flash mode Local M/Multi
2.4G slave mode TTL/ M/Multi
Optic slave mode TTL/ M/Multi
Slave unit compatible camera Nikon i-TTL/M/RTP flash(master unit uses TTL wireless flash trigger X1N etc)Canon EOS E-TTL II/M/Multiflash(master unit uses TTL wireless flash trigger X1C etc)
GN( 1/1) To be notified(m ISO 100,with reflector)
Flash duration 1/220s-1/10000s
POWER 600W
Power control 9 steps:1/256~1/1
Multi flash √(times:100 times;frequency:100)
Flash exposure compensation (FEC) manual,FEB:±3 stops in 1/3 increments
Flash sync HSS(1/8000s),first curtain sync,(second curtain sync ?)
Flash delay 0.1~10s
Fan √
Beep √
Modeling lamp(LED) 10W
Optic slave flash S1/S2
Screen Dot matrix LCD screen
WIRELESS(Optic and 2.4G)
Wireless flash function slave,off
Controllable slave groups 5 groups:A, B, C
Distance Optic indoor:12~15m/39.4~49.2 inchesoutdoor:8~10m/26.2~32.8 inches
2.4G 100m
Channel Optic 4 groups:1, 2, 3, 4
2.4G 32 groups:1~32
POWER
Power Lithium(11.1V/8700mAH)
Full power flash times 500 times
Recycling time 0.01s-2.5s
Power status √
Power saving Power off automatically after 1 hour’s none operation
Triggering mode 3.5mm port,PC port,wireless remote port
Color temperature 5600±200k
Size To be notified
Weight 2.9KG
Источник http://flashhavoc.com/godox-ad600-witstro-ttl-strobe-announced/
