Тема заглохла. А ведь интересная и новшевства http://chdk.setepontos.com/index.php/topic,4202.msg54643.html#msg54643 в прошивке появились :!:
дополнительно:
“14:TimeLapse” = Create pictures every [user set 1-999] sec. Example : 100 x 5s --- take 100 pictures at every 5 sec.
Right – increase time by 1 sec
Left – decrease time by 1 sec
Play – increase # of pictures by 1
Menu – double # of pictures (after like 10 million it goes back to 0)
“15:AFPSelection” = how you can select the Auto Focus Point
Standard = nothing changed from original set
Wheel Off = you can NOT use the wheel when selecting AFP. You can still use the Up, Down Left and Right button + the presets for APF (eg. : set + zoom out)
Blocked = You can only use the presets for APF (eg. : set + zoom out)
“16:AFPoints 1” = set the Auto Focus Point
the AF helping light of my external flash doesn't work when you're using a set that is not standard.
Use left/right in the info menu to move the cursor and set to activate/deactivate the selected points.
If all points are selected in a set the menu will show
TLLCRRB
this stands for top, left, left-center, center, center-right, right, bottom.
the point where the cursor is set to will be in lowercase. non-selected points will show a blank, with cursor set on them a @
“17:AFPoints 2” = see “16:AFPoints 1”
“18:AFPoints 3” = see “16:AFPoints 1”
“19:Review time” = # of seconds picture will be displayed after taking it. This can now be set to
Hold : display image until any button pressed
OFF: doesn’t display any image after picture was taken
1 to 30 sec : display image for user set time --- the maximum values are user settable in the file user_settings.txt, they are not fixed to 30 s
“20:AutoPowerOff” = puts camera into sleep mode. This setting can be set to :
Off: never goes into sleep mode
1 to 60 min : goes into sleep mode after user set time (1 minute increments) --- the maximum values are user settable in the file user_settings.txt, they are not fixed to 60 min.
“21:FlashExComp” = Flash Exposure Compensation. This setting can be set to :
-6 to +6 in 1/3 increments (standard was -2 to +2)
